We are trying a shrink fit of a sleeve in an end cap under internal pressure but we are getting some strange results in a couple of places. See attached pictures, anyone seen this behavior before?
Works fine w/o the shrink fit, but when I apply it to the two faces with 0.24mm overlap the base deflects in the wrong direction and there is some strange deformation of the flange near the bolt hole..
Cheers.
Are you change the deformation scale of model to 1 or true scale? Do you use shrink fit? (Types of contact)
