We are using eDrawings 2009 to view DXF files exported from Anvil. We recently began having issues with opening the files (Error in opening file). After research we found that the users having difficulties were running SP3. We had one user running SP2 and had declined the request to install SP3. He was able to open the files fine.
Is there a way to download SP2?
Also, is there a way to disable the auto-install of updates?
No as the one on the SW website gets replaced by latest one. You can check if you have a copy/dump of SP2 or can ask you VAR to send you a copy.
Disabling auto install must be a window setting. And as far I remember, SW SPs updates are only installed if you want to install.
