Hi i am making a hydraulic cylinder for my college project and i need to make a sort of realistic render using photoworks, i have currently modeled this model attatched but i want to achieve this type of realness, materials, colours and overall so the cylinder looks real itself, but from my render the rendering looks rough etc, how can i achieve this please, i want the outcome to look fairly similar to this other image attatched.
(I know it wont be extremely realistic but i want it better than what i am rendering now quality wise)
Adam, are you applying the material, texture, appearances, etc. properly. From the render picture, it seems you are using a default plastic material and hence is the result. Try your hands on the rendering tutorial under Help > SW Tutorials.
Also have you heard of PhotoView 360. If not then investigate on PV 360 as it is much better and easier to use render software as comparison to PW.
If you search across on this forum, you'll lot of interesting stuff about both PW and PV 360 which can help you learn these software much better.
