I just installed SW 2010 SP3.1 on my home computer. I want to put a vault on the same machine as I have several drives at over 3.75YB of space. I was planning on using drive J (640GB) for my Vault.
The vault installed no problem, I can log in to it through Solidworks and I see the default vault setup. The problem is whenI try to install the Vault Admin from the CD, I keep getting the following error.
Error 1334.The file 'pdmworks.chm49' cannot be installed because the file cannot be found in cabinet file 'Client64.cab'. This could indicate a network error, an error reading from the CD-ROM, or a problem with this package.
If the installation fails, contact Technical Support.
If you continue, you may encounter further errors. If you contact Technical Support, be prepared to provide the installation log files available in this directory.
I've installed the Vault Admin tool before with the DVD at work (I'm using the take home license). Any idea what I can do? Here's the log for it also.
Rich
Tried installing it from my other CD drive and same thing.. the VAR said to copy the DVD on to the local harddirive and try to install it from there. Still getting the same error.. Any ideas?
