i continually get error messageslike the one below when editing a design table that SW2010 creates. i cannot figure out why the offending feature is an issue. until this is fixed SW ignores all edits to the design table and "does not update" it.
I've gotten this messages similar to this lots of times. Usually it's because I generate a Design Table, then go back to the part and make some design changes. If I change a dimension name or a feature name and it isn't the same as the one I first created , the error message appears. It normally corrects when I delete the entire column, and then re-link the dimension or feature.
i've run into that before when i had leftover mates in my design table which i had previously deleted in my assembly.
