Hi guys,
Ive been looking all over for this and cant seem to find an answer. I know solidworks made smart fasteners available in the standard version how can i then take an original solidworks toolbox from Professional and copy it over to (were)? and somehow (connect) it to solidworks standard so it would be recognized and be able to be used?
Any help would be appreciated, we all know this is somehow possible since the buttons do exist in the standard for opening smart fasteners, or the toolbox itself.
Thanks!
the reason is if you have a network install of SW you can have SW on as many computer as you want, you may have 3 seats of SW, 2 standard and one pro, so everything is installed on every computer so if you jump toa ny of the computers there may only be the standard left and toolbox wont be avalable.
and if you get everything setup in toolbox, in the standard version, if you buy the upgrade to office pro you are ready to run.
again you can complain all you want, bitch and moan, you don't have access to toolbox. you have to buy office pro or prem, sorry thats how it is.
smart fasteners will fill the holes with the correct bolt with the fastener you called out with hole wiz and if you didn't pick a fastener it will use the default fastener that you can pick or the standard is socket head bolts and put the in the size it thinks should fit the holes in your part. all the setup you do in standard so if you send the file to some on that has pro or prem they can add the fasteners with smart mates or drag and drop from toolbox, then they can resave with the option to have all the bolts or anything from toolbox saved as outside part files so if someone is on standard they can see and use all the items from toolbox.
shit back in the day before SW bought toolbox it cost $2k buy its self and you had to pay a yearly maintenace on that. now you get all the office products for $1500, over $4k+maint for 5 or 6 add-ins including edrawings pro, today.
