I am having issues with moving parts around in an assembly. When I click on a part face and drag to move the part, there is about a 10 sec. delay before the part actually moves. Also, while adding mates to parts, there is a delay before the part moves into place and if I try and move components that have distance limit mates the move is not smoothe but very slow and choppy. Is this system memory related, video card or some other culprit? I am currently running Vista X64 with 4 gig of ram and am in the process of upgrading to 8 gig of ram. Video card is an ATI Fire Pro 5700. Just curious if anyone else has these problems?
Kevin
No answer for you but I am seeing something similar that I haven't figured out yet. I have noticed that my problem is worse with larger assy files. In order to move or rotate in an assy, I have to click and hold for a bit before it will go. It's like I have to wait for it to go through and select everything and that takes longer than it used to be. Once I start the move it moves fine - it's just the getting started that seems to having the problem.
Is this similar to your issue?
WT
