Using EPDM2008 and computer crashed with files checked out. Files are now not accessible due to 'Checked Out on another machine'.
I guess I have 2 options:
A) get the first machine back up and running, hopefully with no loss of data OR
B) using EPDM admin, undo Check Out. This will result in loss of work.
I am first working on option A. NO LUCK. As an option I have pulled drive and installed in back up machine. All directories seem file except, you guessed it, C:\PDMXXXXX. When I click on the directory I get the following error message:
No database is connected to view.
Is there any way to connect database? FYI, this back up machine already had EPDM on it under its C: drive. The drive I pulled is mapped to the E: drive.
Finally, if no option to connect to database based on my current setup is there another option to A and B.
Your solutions, ideas and comments are appreciated.
Thanks, Tim...
Hi Tim -
Go to the SolidWorks website (subscription services, knowledge base and look for solution: S-038423
This solution might help you re-establish the local view.
https://customerportal.solidworks.com/eservice_enu/start.swe?SWECmd=Login&SWEPL=1&SWETS=1275561430358
Regards,
Joy
