We have many older drawings done with Autocad and we use eDrawings as the default viewer in our production and purchasing area to view and print them. Many of them have multiple sheets and when we generate multiple sheets in Autocad we typically just place multiple drawings in the model view rather than setting up layouts. Up until eDrawings 2010 the print command had a 4th option for "Print Selected Area" which allowed you to position a green dashed box to print an area and that is what was used to print each sheet of these multiple page drawings. In 2010 it looks like that was removed so we cannot print just a portion of the model view area.
Is that feature coming back? Until then we are staying with 2009.
Robert,
The option is still there just moved slightly. What you want to select is "Current Screen Image" and then there is a window selection tool below the preview (see image). If you select this it gives you a correct ratio window to select as your print area. You'll see the scale change accordingly when you zoom to a smaller area. The other buttons allow you to Pan, Fit, etc. to get the exact page you want.
Paul
