modify weld symbol?
Question asked by Ari Arponen on Jun 1, 2010
Latest reply on Jun 1, 2010 by Jason Weatherall
Hi there, above you can see the weld symbol. The idea is to make weldment to both sides of the part. Is there any way to remove the dashed line (shown in upper weld symbol). Because then it would be correct symbol. I found the "symmetric" option in weld symbol properties, but then it removes text under the line and thats not correct either. So is there a way to make the weld symbol so there are just solid line between the markings? Otherwise I need to manually make whole symbol, or fix it in the dwg which I send to subcontratcor.
Thanks.
