Hi
I am facing one issue with Save as DWG.
I am saving Drawing file into DWG format.And then just editing in autocad.
The Dimension position just changing from Right to Left or Upper to Downwards
I have attached video.Just check it.
Regards
Anil Ghotekar
Solidworks 2010 SP 3.0
You cannot perform normal ddedit's to dimensions transfered from Solidworks to AutoCAD. Solidworks creates new dimension styles with exported dimensions. It is easier to either dimension completely in AutoCAD or edit the required dimension in Solidworks.
