Hi Guys,
I have a rather large design. As I recall when I first set up the design table I had the option to allow dimensions to be changed from within the model. I chose not to allow this option.
I am now having some problems with some larger configurations I have added and so far have not been able to isolate the problem.
I would like to change the option back to the choice of allowing changes from within the model. Once the problem is found and fixed I will want to cange back.
If anyone can tell me how to change this option it would be most appreciated.
Thanks, Bill
Change the Feature tree to the configurations tab. Then hit the + beside the TABLES tab to expand it. Then you RMB pick on the design table and choose EDIT FEATURE. Under the EDIT CONTROL area of the Design table properties is the option to enable the Allow Model edits to update the design table.
