I have a 5000mm plate that is paralell, i want 4800mm of this plate to be paralell and then from 4800-5000 i want a 305 degree rad, so the plate is bending
Adam if you see ~$ in front of the file name, then assume it is a temporary file that gets created when you open you files and they get removed once you the files.
There can be various ways you may be able to achieve what you need.
Draw the required bend cross section profire and do a simple extrude.
You may use use sweep/loft
You may use sheet metal features.
If none of above solve your issue then post the actual file to look at..
