13 Replies Latest reply on Mar 26, 2018 7:08 AM by Joe Cann
    Set all views to 'link balloon text to specified table'
    Checkcheck Master
      Is it possible to do this for multiple or all views instead of clicking all views apart ?
      Greetings !
        • Re: Set all views to 'link balloon text to specified table'
          Roderik Vreeke
          I've got the same problem.
          When I sort the BOM, the balloons of some views are not changing with the item numbers.
          I have to turn on "Link balloon text to specified table" for every view.
          This is annoying and causes errors.
          I recon that there must be an option to set this option on for all views.
          Does this option exist?
            Alan Woolston
            I have the same problem. None of the veiws are EVER linked to the weldment cut list, every one has to be set manually.
            Hey Solidworks, pull your finger out and fix this. I see multiple posts about this going back to 2008 and no solution.
              Roderik Vreeke
              Same problem!
              When does the hurting stops?
                Anthony Macke
                this existing thread contains a macro to link all drawing views to their corresponding bom.
                ive been using it for a while now with no problems at all.
                https://forum.solidworks.com/message/125802#125802
                here is the macro:
                Private Const strApp As String = "Link2BOM v1.00"
                Public Sub subMain()
                    Dim iCnt, iTotal As Integer
                    Dim retVal As Variant
                    Dim sBOMname As String
                    Dim vSheetNames As Variant
                    Dim swView As SldWorks.View
                    Dim swSheetView As SldWorks.View
                    Dim swDrawing As SldWorks.DrawingDoc
                    Dim swFeat As SldWorks.Feature
                    Dim swBOM As SldWorks.Feature
                    Set swModel = swApp.ActiveDoc
                    Set swDrawing = swModel
                    Set swFeat = swModel.FirstFeature
                    'Get BOM name
                    Do While Not swFeat Is Nothing
                        If "BomFeat" = swFeat.GetTypeName Then
                            Set swBomFeat = swFeat.GetSpecificFeature2
                            Set swBOM = swBomFeat.GetFeature
                            sBOMname = swBOM.Name
                            Exit Do
                        Set swFeat = swFeat.GetNextFeature
                    Loop
                    vSheetNames = swDrawing.GetSheetNames
                    iTotal = UBound(vSheetNames) + 1
                    iCnt = 0
                    Do While iCnt < iTotal
                        'Set view linked to BOM
                        retVal = swDrawing.ActivateSheet(vSheetNames(iCnt))
                        Set swSheetView = swDrawing.GetFirstView
                        Set swView = swSheetView.GetNextView
                        Do While Not swView Is Nothing
                            retVal = swView.SetKeepLinkedToBOM(True, sBOMname)
                            Set swView = swView.GetNextView
                        Loop
                        iCnt = iCnt + 1
                    Loop
                    retVal = swDrawing.ActivateSheet(vSheetNames(0))
                    swApp.SendMsgToUser2 "       Linking is complete...       ", swMbInformation, swMbOk
                    Set swApp = Nothing
                    Set swModel = Nothing
                    Set swDrawing = Nothing
                    Set swFeat = Nothing
                    Set swBomFeat = Nothing
                    Set swBOM = Nothing
                    Set swSheetView = Nothing
                    Set swView = Nothing
                    End
                    Checkcheck Master
                    Nice macro Anthony, thanks !
                    I've added a simple 'No document loaded' and 'Only for drawings' message.
                    Greetings !
                        ' No document loaded error handler
                        If swModel Is Nothing Then
                            MsgBox "No document loaded !", vbCritical
                            End
                        ElseIf Not swModel.GetType = 3 Then 'When no Drawing
                            MsgBox "This macro is only for a drawing !", vbCritical
                            End
                        'Get BOM name
                                Exit Do
                        Loop
                        iCnt = 0
                            Loop
                            iCnt = iCnt + 1
                        Loop
                        Set swApp = Nothing
                        Set swBOM = Nothing
                        End
                    Brian Marks
                    Ok that looks like a great Band-Aid but has it been fixed by SolidWorks yet.
                      Joe Cann
                      Thank you to everyone who contributed to this post. I've got a drawing here with 63 individual views, only a handful are linked to the bom, it was taking about 2 minutes per view to think about the change when I clicked the 'link balloon text...' check box. This macro has saved me about 2 hours of just staring at my screen!
