I've got an assembly that has 90 of the sme nut, bolt and washer. I've tried using a feature driven pattern to make this a quick and easy task and to greatly reduce my top level mates but the feature driven pattern won't pick up the holes that I made using a mirror feature. I tried using a 3D sketch and a sketch pattern but that didn't work either as you can't use a sketch pattern to locate parts. I also tried making all of my holes in one 3D sketch and I think that would work but it would take forever to place all the holes as 3D sketches don't have linear patterns or mirrors.
i'm sure people do this sort of thing a lot, i hope somebody can help me out.
If the hardware is in different orientations then you can't do it all with one feature pattern since all instances will be in the orientation of the parent. So take a look at what areas can all be the same and if possible, put in the holes with the Hole Wizard as you can drive the fasteners with that.
WT
