JMJeff Mungle20/05/2010
Has anyone else had this problem? Our company logo is part of our title block and sometimes you will save a drawing and go to open it up again and the logo is gone.
The funny/wierd thing is if you look at the thumbnail that was saved when you saved the part it shows the Logo. Then the even stranger part is if you lrt your curser hover over the sheet tab at the bottom of the drawing and get the sheet preview to pop up at the bottom, the logo shows in that as well.
It happens all of the time and I am not sure why. Sure you can reload the sheet but then any special links you have made to the title block are gone and you have to re-establish them. This is not a huge deal on a one sheet drawing but when you are working on an assembly/detail drawing package with 30 - 40 sheets and you lose the logo off of all fo them then it poses a big problem.
The only way I have found of getting the logo back is to copy & paste and then resize to fit the title block and do this on each sheet.
Anyone else came across this issue and have any ideas on what to do to keep this from happening?
Jeff
I have attached some examples.
