Hello.
I would like to plot the stress distribution across a part cross section. I used section clipping and drew a 3d line where I would like the stress to be plotted (see image 1), but cannot figure out how to produce a nice clean graph.
I can do a very rough version by probing the face at various points and then clicking the plot button - but the line is jagged because my points are not uniformly distributed (image 2). I would like the program to automatically select a nice array of data points along the line I've defined - is this possible?
Thanks very much,
Andrew
Attached is a sample example. I defined Sensors as Simulation Data > Workflow Sensitive (turn off "link to selection") and then used points that I had previously defined instead of entering X, Y, Z values (you could import values from a csv format file).
Then when probing the result, I changes to sensors and selected my Workflow Sensitive list, and then click on plot and voilà you get the smooth images at the bottom.
