Greets all.
Had a few questions re: master model top-down design and performance/efficiency.
In particular, I'm looking for any documentation that might exist that provides info on
the best way to handle (and edit!) large master models.
I (we) do alot of consumer product / plastic part design -- lots of complex surfaces
that the industrial designers like to change half way through a project.. in the office
we use both SW and ProE. For some reason the ProE guys have never had as much
trouble as we SW folks do in making late-game edits. I'm wondering if its our master
model approach.
So on our most recent project, we tried the "ProE Approach" lets call it.
This consists of a very light-weight master part that contains all the sketches planes
curves points etc to drive every other feature in what will be the child parts. The master
contains only the outside (complex) casework solid parts.
We find we're constantly going back into the master to add sketch data to locate some
snap feature we didn't think about when the master was made.. we do this 10 times a day
until all of the 'intelligence' is in the master.
Usually we'd build up the whole product in this master part.. and then spin on children,
make an assembly, and add the non-critical features (features that don't depend on
others) in the child parts... the assembly would be use for interference detection, animations,
BOMs, etc etc.
This time, we're inserting the master part into every child part.. and cutting away what we
don't need. Seems to be working a charm so far.. but i'm worried what adopting this approach
for larger project might mean. will the heirarchy become too heavy? will we need to have
50 parts open to make one change? etc.
We can't be the first ones to be going through this sort of evaluation.. so where I can i find
info on the most efficient way of doing this? for example, how much detail should I add
to the master? should I make the master as big as possible before spitting out child parts?
should I keep the master as light as possible and make all the changes in the child?
if more than one person is working on the project (we have no PDM), who gets control
of the master? How do you "share" and assign the parts? how do you get them all back
together with out major reference issues?
Sorry so long-winded.
Thanks!
-Tony
Hi Tony,
As a primer, in SW, go to the help>Consumer Product Design>Molded Product Design - Advanced. I feel that we've made a lot of headway in this area over the last few releases and now the Master Model Techniques for SW are stronger. In 2009 and 2010, we strenghten the capabilities of "Save Bodies" and "Split Part" that actually make them pretty robust and usefull and replace the manual method of inserting bodies and deleting bodies for what does not pertain to that derived part. There are basically three (maybe four) different techniques that you can take to mimic the MM approach, depending on your needs and requirements. If you have access to the SWW presentations, there are a few slides I presented in my "Advanced modeling 301" presentation that speak to the Master Model Technique.
Regards
Mark
