To Whom May Concern,
Recently I been look at electrical routing, can anyone tell me how to add more than 2 plug into a standard cable please. The reason I want to use standard cable function is because I have design a harness which consists of 9 plugs connect to a 20ways plug and I would like to use this harness apply in other places and try to rout the the extra length of harness in some shape. (same harness apply in else where can reduce the cost of manufacturing )
Appreciate any suggestion
Cheers,
If you make a From-To list, you should be able to do what you want. It will allow you to have more than 2 connectors and route the wires as desired.
