Hi everybody
I am new to the forum and need help.
I make the weldment you see in the picture. (3' wide x 6' long). I am debating on whether or not to use a weldment to create this entire thing or make several weldment assemblies, or just continue to make it as an assembly. At the drawing level I can show individual parts that have detail, can you do this with a weldment? Wil I wind up spending so much time creating my 3d driver sketch I could have just made an assembly? Is a weldment more robust? please advise.
cutlists can be beastly if you really need them.
bear in mind that a lot of companies do not manufacture their own parts, instead they send out to vendors to fabricate. in this case a cutlist is irrelevant, in that, if the vendor is truly competent they can figure the cutlist out on their own.
however, if you are the manufacturer and fabricator then i understand your concerns about the cutlist.
if you did your weldment as a single part (all features in one file) in-context is available and does work with individual bodies.
parts inserted into parts do not play well with pdm.
configurations do not play well with pdm.
