Annoyances so far, and no I can not duplicate them.....these issues just seem to happen for no reason at any given time....
Image quality, keeps changing back to its lowest setting.............have to go into options and reset it
Mates, go into conflicting mode, have to delete them and then re-mate the parts in the exact same way......seems to be a configuration issue.
Save a file and get a gray screen with white block popping up all over the screen......
Save As PDF, works, or wont work, goes fast, takes forever..........very inconsistent.
Note Editing, when dragging one note to another location in a drawing and your not careful and drag over an existing note the notes will get combined automatically
MEMORY LEAKS, STILL HAVE THEM, SW WONT RELEASE MEMORY RIGHT..........................FIX IT ALREADY, this has been going on for years.
Open a DXF file, select sheet template, but when finshed opening it has the wrong sheet size and template..........
Revision table, top row has merged and centered cells, text will only fit in left columns size (word REVISIONS ends up being REVISIO)....
This is just for starters, who else has similar issues?
Image Quality: Have you changed this in your part template? It is part specific, so part templates, and any part already created need to be adjusted. Also, if you alter it in an assembly, and then save the assembly, it will not flag the part to be saved as well. It may assume that the part is "up to date" because there were no changes, if the only change was to the image quality.
Memory Leaks: SW2011 preview at SWWorld 2019 showed them fixing memory leaks. They did this by releasing all associated memory when part files are closed. If it works as shown it should be nice, we'll see if it actually makes a huge difference when it comes out.
