Hello All,
I would like to do an analysis on a welded frame. If I create welds using the Insert>Weldments>Fillet Bead, would the connection transfer to Simulation so that I don't need to do anything else for the connections? Or should I just create the joints using Connections>Edge Weld in Simulation? I tried to do it in Simulation and had issues being able to select the right faces to create the weld. Thoughts? Thanks.
-Scott
if you defind fillet beads in solidworks, in the simulation it assume as a seperate body. it will not consider as a welding connector.
While using the Edge weld connector, the terminated part should be a sheet metal or surface part.
What is mean weldment analysis? what is the output you are looking?
Regards,
Ameer .C
