JPJack Poon04/05/2010
Hello
          I've made a 3 Degree of Freedom revolute joint of three axes to rotate about and specified each one as a rotary motion. When I run each one individually, the joint rotates about its respective axis as I wanted it to; however, when i try to run more than one rotary motor, solidworks motionworks only runs the rotary motor closest to the end effector. Am I missing something or need to specify more or is motionworks in capable of running multiple rotary motors at once. Thank You!
        -Jack Poon
P.S. I am able to run multiple linear motors simultaneously so I believe I may be lacking something.
