Hello, I need to automate some drawings I use very often. My idea is to create a database in excel and then use a design table to create the 3D and 2D model. I would like to control everything from the excel file (dimensions, tolerances, text). Now, I am able to control dimensions and I think there is an option to control tolerances. My question is, if it is possible to control the text fields in the drawing, for example: drawing name, date, material, finish, etc.
Any help or ideas are appreciated!
Thanks.
SW2009.
The DT can be used to propagate Custom Properties to the part and assy models. Those properties are then read into the drawing via linked notes.
http://help.solidworks.com/2010/English/solidworks/sldworks/legacyhelp/sldworks/Detailing/HIDD_SELECT_PROPERTY.htm
Rather than re-design the wheel, you should check out the Partner Products listed under Knowledge Based Engineering at http://www.solidworks.com/sw/products/engineering-software-partners.htm
