Lets say I have 500 files in an EPDM valt and I want to change a data field for all of them at once. So I have 500 PDF files and the "Type" field is "Capacitor" but I want it to be "Resistor". What is the easiest way to edit 500 records all at once., instead of going to 500 data cards and editing each one?
Hi Mike -
If they are all in the same folder you can RMB on the folder and use Update values in files...
Or, you can write a dispatch utility to help... (see attached dispatch and video)
Regards,
Joy
