We have a user who has completed some projects and is cleaning out his local PDM works. There are dozens of part files remaining that have the green triangle indicator showing that they are newer than the vault. All of these files are read-only as he does not have ownership of them. It appears that these files are actually the same as the vault. Being read-only, he couldn't have saved any changes locally anyway. Any ideas or thoughts?
Don, it has nothing to do with read-only files. That is a microsoft function. The only time you are accessing vault data, is during a check-in or check-out. If someone else owns the part, you can still check it out. PDM copies the file from the vault to your specified location (hard drive). Then you're free to do whatever you want to those files. It's during the check in process that it matters most. He will not be able to check in those files you are calling "read only" because he is not the owner.
PDM is just doing copies to or from the vault. It's not actively looking at your files, except for the icons that give you status feedback in your local view.
You might want to discuss this with you VAR as I feel you guys may be operating under some perceived functions that are true. Hope that helps.
