Hi everyone!
Okay another problem
I made a simple assembly of elbows, pipes, tees, and unions, because im taking our new library of parts for a test drive.
I went to change the route diameter, and unfortunately the radius stayed the same while the rest of the parts changed from 2" to 4", so of course, the 4" elbows didnt like the smaller radius, and now ive got pretty red elbows and error messages instead of 4" elbows. Upon returning to the main assembly, the elbows just simple arent there anymore because a valid configuration wasn't available.
Why arent my radii updating to account for the new size of pipe?
Thanks!!
The main thing that was needed you can deduce from the inclosed screenshots.
Once I changed over the name for that sketch as well as the name for the dimensions that define it in the design table everything started to fall in it's place.
To be exact, it seems that for an elbow one needs two sketches :
2. one named ElbowArc (that defines the actual curve). FYI, the ElbowArc needs two measurements : One called Bendradius@ElbowArc and one called BendAngle@ElbowArc
In my experience naming them something else tends to give strange results.
It was a bit of nuisance to change the sketch name because the variables are determined by the table and the table is determined by the sketch and seeing as that I don't use inches at all I don't have the values or info at hand to simply remake it from scratch.
