I have no penetration contact sets defined in a model that uses exclusively shell elements. Plotting the deformed geometry after an analysis shows pretty clearly that the no-penetration constraint is ignored. Does no-penetration work with shell elements?
No penetration should work with Shells, check that the deformation scale is set one or ture scale.
