So here's my latest problem, and its possibly a stem of problems with a "route" cause, pardon my pun.
All our routing parts are in the design library. Lately, when I want to "start by drag/drop" it is unresponsive, that is to say, i can drag a routing component onto the screen, but nothing happens. It doesn't prompt me to choose pipe and elbows anymore, and doesn't automatically make stubs to build onto. Instead, it is treated as a regular part in an assembly. If i try to start a route from it after, i can make a route, but the component I initially dropped onto the screen doesn't become a component within the route assembly.
Then, the problems continue, If i save that assembly, and try to re-open it, the original part loses its location and I have to browse and relocate it. Parts within the route assembly do not need to be relocated.
How do i get Route on drag/drop to work again?
Why would solidworks forget the location of a part?
What is a good reliable set of routing options/selections in tools/option?
Doug
No, I mean quite the opposite. You must have only one elbow with any given names - with multi-configs etc. As we have setup in the normal routing library. You can then use these in any number of different assemblies.
I think yo need to get some help from your VAR, it sounds like there is a problem with your paths or other settings.
Andy
