When I convert this part to sheetmetal, the last bent leg is cut off.
The original cust. model had 1 faulty face that healed at import. I tried exporting as _xb, then using that model.
Same results but no import error. I can re-model it f/ the print, but would like to know how to recognize the error and fix it.
The flat pattern is not correct to make the part so that is a big issue.
Hi Brian
There is a slight difference in you plate thickness. See attached PDF
SolidWorks cannot unfold different thickness plate.
Mark (SolidWorks 2010)
Hi Brian,
Were you can see that line the faces are not tangent and there is a differance in material thickness which SW will not let you convert to sheetmetal.
Michael
