Hello All,
I have a big frame that has a bunch (over 100) of connections. I know how to create a bolt connection for a single hole. Is there a way to pattern or copy bolt connections for more than one hole? Or do I have to create a new bolt connection for every hole? Thanks.
-Scott
If you created the hole using hole series, than you can add the bolt connectors to all the holes.
Hope this helps,
Ramya
