Hi, I m training do modulate a graphite foam to make a thermal analysis of that material.
I have made same experiences but i can't get it Dane.
The issue that i have, is to make little bubbles and introduce them chaotically in a volume. Is that possible...
Can someone help me.
Try asking this same question in the "simulation" category. This is the sketching category.
There is an easy way to simulate non-solid materials for the fluid simulation package, I'm not sure if that is also possible with the thermo/stress package; but someone who frequents that category will be able to help you.
If you really need to actually solid model the bubbles, then you would want to create one bubble, then use pattern feature to pattern it to fill an area. Do one pattern to make a 2D array, then do a second pattern to pull that into the 3rd dimension. This will probably not only bring your computer to a slow crawl, but probably take it past the braking point. A much better solution is to just use an analysis that accounts for the holes in the foam.
