I an thinking of upgradint to SW Pro,
Am I correct in thinking that renaming files in the PDM upates links instantly,?
currently renaming files with SW explorer is a painfull task, renaming one file at a time and all the searching for links ect (again, one file at a time)....
will using the PDM solve this problem for me??
There are two options (other than PDM)
1. You can use pack and go (if you are renaming multiple files) and rename the files instantly. You can add prefix or suffix to all file names.
2. First rename the files (if files to be renamed are fewer) and then change `Reference..' in assembly (without opening it).
