Is solidworks able to take a solid in assembly and create cloud point data? The reason behind this is so that we can use this data to compare with another source.
-Steve
-Steve
https://forum.solidworks.com/message/10441#10441
The above discussion has some info on your topic. Save as a .stl file appears to be the answer. You can't import the other data into SW?
