We have our PDM Vault set up to create a PDF of Drawings when there checked in. Is it possible to view the PDF's of the drawings instead of opening E-Drawings. I understand that you can use the 'Classic' interface but the 'Search' interface is a lot easier to use.
Regards
Robert
RMB click on the drawing from with in SolidWorks Explorer, view as PDF
But that is only the case if when the drawing was check in last, you checked "Create PDF files in the Vault on normal check in of SolidWorks drawings in the VaultAdmin utility.
