Is there a sketch command to combine splines? I have a spline I copied form an imported part. I mirrored that spline to get the full arc but now I have 2 seperate splines. How can I make them one spline?
Actually, Grant, I'm not sure how to do this with any precision. However, depending on what you need this for, you have some options. For instance, you can probably turn these two segments into a single Composite Curve if you need to use it for a sweep path or such. Otherwise, I'd imagine other people will pipe up with some suggestions.
I'm using it to extrude my shape (or a cut that doesn't matter). I'm making a nest for a part to rest in.
What I did was make some points on copied spline then sketched a spline over the copied and mirrored spline. It worked but Im not sure thats the best way. Maybe bring the imported part into my part and combining them would be better then copy entities?
I will try and find the post by Andy, one of the SW employees. There is a way to combine two splines into one.
Click on both splines, and chose the constraint "curvature" to give them equal tangency and curvature. Then you can click on the point between them and press the "delete" key. This will turn it into one line spline.
Grant,
You could try a Fit Spline. I don't know what the down side would be, as I've never used them on other splines, just on lines and arcs.
Jerry Steiger
Post Found!: https://forum.solidworks.com/message/77029#77029
