I am attempting to pop up a user form in response to a state transition so that the user can enter some data that will be used to set variables on the file. I have added a hook for EdmCmdType.EdmCmd_PreState and in OnCmd the code looks like this:
EdmCmdData[] cmdData = (EdmCmdData[])ppoData;
int sourceStateID = cmdData[0].mlLongData1;
IEdmState6 sourceState = (IEdmState6)vault.GetObject(EdmObjectType.EdmObject_State, sourceStateID);
if (sourceState.Name.Equals("Acquiring Oracle Number"))
int fileID = cmdData[0].mlObjectID1;
OracleData data = new OracleData();
OracleNumberEntryForm form = new OracleNumberEntryForm(data);
DialogResult result = form.ShowDialog();
object obj = vault.CreateUtility(EdmUtility.EdmUtil_BatchUpdate);
IEdmBatchUpdate2 updateUtility = (IEdmBatchUpdate2)obj;
IEdmVariableMgr6 varMgr = (IEdmVariableMgr6)vault;
object oraNumVarName = "ORACLE_ITEM_NUMBER";
object oraDescVarName = "PART_DESCRIPTION";
IEdmVariable5 oraNumVar = varMgr.GetVariable(ref oraNumVarName);
IEdmVariable5 oraDescVar = varMgr.GetVariable(ref oraDescVarName);
object oraNumVal = data.Number;
object oraDescVal = data.Description;
updateUtility.SetVar(fileID, oraNumVar.ID, ref oraNumVal, "", (int)EdmBatchFlags.EdmBatch_Nothing);
updateUtility.SetVar(fileID, oraDescVar.ID, ref oraDescVal, "", (int)EdmBatchFlags.EdmBatch_Nothing);
EdmBatchError2[] errors = new EdmBatchError2[10];
Array errArray = (Array)errors;
int errCount = updateUtility.CommitUpdate(out errArray, null);
if (errCount != 0)
handleCommitErrors(errArray);
If I select a checked in file and move it through the transition, the OnCmd is called as expected, the form pops up and all is well until the CommitUpdate method is called. The call fails with one error being returned. My handleCommitErrors method shows the following details:
Using ProcessMonitor I don't see any other process other than SolidWorks trying to access the file:
61348 10:25:20.4206792 AM sldworks.exe 5676 CreateFile C:\_EPDM\Part1.SLDPRT SUCCESS
61349 10:25:20.4207313 AM sldworks.exe 5676 ReadFile C:\_EPDM\Part1.SLDPRT SUCCESS
61350 10:25:20.4207621 AM sldworks.exe 5676 CloseFile C:\_EPDM\Part1.SLDPRT SUCCESS
61351 10:25:20.4208332 AM sldworks.exe 5676 CreateFile C:\_EPDM\Part1.SLDPRT SUCCESS
61352 10:25:20.4209103 AM sldworks.exe 5676 QueryStandardInformationFile C:\_EPDM\Part1.SLDPRT SUCCESS
61353 10:25:20.4209281 AM sldworks.exe 5676 QueryBasicInformationFile C:\_EPDM\Part1.SLDPRT SUCCESS
61354 10:25:20.4209485 AM sldworks.exe 5676 LockFile C:\_EPDM\Part1.SLDPRT SUCCESS
61355 10:25:20.4209704 AM sldworks.exe 5676 QueryStandardInformationFile C:\_EPDM\Part1.SLDPRT SUCCESS
61356 10:25:20.4209856 AM sldworks.exe 5676 QueryBasicInformationFile C:\_EPDM\Part1.SLDPRT SUCCESS
61357 10:25:20.4210029 AM sldworks.exe 5676 ReadFile C:\_EPDM\Part1.SLDPRT SUCCESS
61358 10:25:20.4210323 AM sldworks.exe 5676 ReadFile C:\_EPDM\Part1.SLDPRT SUCCESS
61360 10:25:20.4210731 AM sldworks.exe 5676 ReadFile C:\_EPDM\Part1.SLDPRT SUCCESS
61362 10:25:20.4211096 AM sldworks.exe 5676 ReadFile C:\_EPDM\Part1.SLDPRT SUCCESS
61371 10:25:20.4218840 AM sldworks.exe 5676 QueryStandardInformationFile C:\_EPDM\Part1.SLDPRT SUCCESS
61372 10:25:20.4219014 AM sldworks.exe 5676 QueryBasicInformationFile C:\_EPDM\Part1.SLDPRT SUCCESS
61373 10:25:20.4219399 AM sldworks.exe 5676 UnlockFileSingle C:\_EPDM\Part1.SLDPRT SUCCESS
61376 10:25:20.4220413 AM sldworks.exe 5676 CloseFile C:\_EPDM\Part1.SLDPRT SUCCESS
128305 10:25:58.5716653 AM sldworks.exe 5676 QueryDirectory C:\_EPDM\Part1.SLDPRT SUCCESS
129047 10:25:58.8298369 AM sldworks.exe 5676 QueryOpen C:\_EPDM\Part1.SLDPRT FAST IO
129048 10:25:58.8298872 AM sldworks.exe 5676 CreateFile C:\_EPDM\Part1.SLDPRT SUCCESS
129049 10:25:58.8299147 AM sldworks.exe 5676 QueryBasicInformationFile C:\_EPDM\Part1.SLDPRT SUCCESS
129050 10:25:58.8299280 AM sldworks.exe 5676 CloseFile C:\_EPDM\Part1.SLDPRT SUCCESS
129052 10:25:58.8300246 AM sldworks.exe 5676 CreateFile C:\_EPDM\Part1.SLDPRT SUCCESS
129053 10:25:58.8300603 AM sldworks.exe 5676 ReadFile C:\_EPDM\Part1.SLDPRT SUCCESS
129054 10:25:58.8300845 AM sldworks.exe 5676 CloseFile C:\_EPDM\Part1.SLDPRT SUCCESS
129055 10:25:58.8301479 AM sldworks.exe 5676 CreateFile C:\_EPDM\Part1.SLDPRT ACCESS DENIED
SW successfully opens, closes, locks and unlocks the file prior to the CommitUpdate command. At that point, the ACCESS DENIED occurs.
I added a bit of code to check the LockedByUser property of the file and it reports that the file is locked by my user.
Do I need to programmatically check out the file in order to call SetVar and CommitUpdate?
Jim S.
A file needs to be checked out when editing its properties.
Hook the EdmCmdType.Pre_Unlock and Pre_UndoLock events if you can, or progmmatically check out the file as you suggested.
I've attached an example of an addin I use to copy the properties of the Default configuration to the '@' file properties which uses batch update.
