10 Replies Latest reply on Apr 13, 2010 2:20 AM by Peter De Vlieger
    Page setup
    Peter De Vlieger
      I know I must be doing something wrong but I can't find the answer anywhere
      What do I have to do to have the page setup remember the drawing color setting so that I don't constantly have the alter it from Automatic to Color/gray scale.
      I'm ashamed to admit that I simply don't seem to find a way.
        • Re: Page setup
          Stephen Burke
          I think its a Template setting. You'll need to set it and save as a Template.
            • Re: Page setup
              Peter De Vlieger
              That's what I thought as well but the question then is how do I set it so that the template will remember it.
              I open a drawing (with the intention of saving it as the new template)
              Do the necessary changes to the settings that I want the document to have
              Go to page setup to set the printer settings for the intended template
              Save it as a template
              Close it
              Open the new template and the drawing color selection is still Automatic instead of Color/gray
                • Re: Page setup
                  Derek Bishop
                  Peter,
                  It sounds like a printer setting. Do you have a way of saving a page setup in the print window. You could also try to select the B&W setting and save to the default printer setup.
                    • Re: Page setup
                      Peter De Vlieger
                      Derek,
                      I'm setting it up for a plotter which we use for some different formats (A0, A1, A2 and A3). The plotter selects automatically between 2 roll sizes.
                      The plotter (Oce TCS300) can be set in color or grey or B&W mod. We always use colours.
                      All the other settings (scale - orientation - paper size - etc.) in the page setup box it remembers.
                      If I leave it on Automatic though it prints everything out in B&W although the plotter is set for colour.
                      When I put it on Color/Grey and do a print then it comes out as we want. Now if it would *@#é$ remember that setting I would be happy.
                    • Re: Page setup
                      Stephen Burke
                      Hi Peter,
                      I tried it there and it works fine for me on SW2010 SP2.1
                      File -> New -> Drawing
                      File -> Page Setup. Change options as required.
                      File -> Save As -> Drawing Template Type. Save it into your Templates Folder (as in Tools -> Options -> File Locations).
                      File -> New -> Drawing Tempate from above
                      File -> Page Setup. The options should be correct.
                    • Re: Page setup
                      Thanks Steven, that took one more little annoyance out of my SW experience.
