I know that we can animate the rotation of gears inside SWX using the tools available. I would like to know can we calculate the stresses getting developed at the matching points of these gear tooth dynamically i mean to say i need to know the stresses inside gears as it actually rotates. I have given 3D contact b/w gears and i dont get a satisfactory results. See the attached image any help is highly appreciated thanks
Hi Shankar,
It's a little unclear, are you taking the loads from motion and applying them in Simulation? Big issue there is that 3-D contact forces are not supported in the automated load transfer so you will get garbage. The problem is that forces need to be specified on the areas of contact, and when it comes to gears, this is a very localized region.
If you're running the motion simulation you can get reasonable contact force results, and it is possible to take the force results from motion to look at stresses in the model, but it will be done manually. If the stresses due to rotation are not as significant as the load transmission through the gears, then you can take the moment force results from motion (ie there is a torque being transmitted through the shafts) and you apply one of those torques to the gear shaft and lock the second gear shaft in simulation with the parts in the relevant orientation for the peak motion force. Define no penetration contact between the gear teeth and away you go.
As far as gear contact force results in motion, you should use precise contact, and you may need to refine contact parameters and sovler settings to smooth out results. Ignore friction since it's a rolling contact.
Hope this helps,
Ian
