When setting up a motion analysis i have tried to add a linear actuator to a face and i am gettin an error stating that the mechanism has locked up. how do i find out which component the error is connected to or how to fix this error?
see attached file for error
Hi Laura,
It's very hard to say from the images what the cause is. I see that you are using flexible subassemblies. Provided that the part you are putting the motion on can be dynamically dragged in the top level assembly it should work. One aspect to keep in mind though, is that if the part with the motion on it moves relative to another component than changes position/orientation, you need to define that as the reference part in the motor definition (or it will lock up).
If you're able to post the model, others and myself on the forum will be able to give more feedback. If that's really an issue, then you need to post images showing the mechanism structure, the part the motion is on, the motion definition to be able to help further.
Cheers,
Ian
