Hey guys, I have been playing with this for a few days and I'm still have difficulty. I've tried all of your suggestions and at the moment can't get any of them work. Apparently what I've read is that when I did my so called 3-D image in autocad it's not really 3-D. When I save out of Autocad I can save it as a .dxf or .dwg but then when I import this straight into solidworks it shows it as one whole part, instead of the 100 or so parts I drew on autocad. It shows each section it imported but it doesn't make each of these imported items as single parts. Thanks again guys for all your help.
Patrick
Patrick,
What is it you made in AutoCAD? You say "the 100 or so parts I drew in autocad". Do you really mean "drew"? Are they 2D drawings of parts? If that is so, then none of our advice will be of much use. You may be able to make each of your "parts" into a Block in the SW drawing. I think you can use those blocks to make SW 3D parts, but it is, of course, just the first sketch.
Jerry Steiger
