We just switched to Solidworks 2010 from 2009 and I had to lengthen a PCB for our layout team. We have a set of “Circuitworks Approved” connectors we keep locked in our PDMworks vault (approved, because we have tested them through Circuitworks with our PADS layout team for rotation and origins, etc). I sent out the update emn file through 2010, and found that some parts are now named differently and some have 180 degree rotations. I am attaching our emn files from Solidworks 2009 and 2010 (Circuitworks 10 and 11 respectfully).
Can anyone shed some light on what may be causing this issue? It seems to be Circuitworks related. What has changed between the two versions?
Naming convention has changed?
2010
AUD-00002-01-A-R Default R25
201.5 -512.477 0.0 90.0 TOP PLACED
2009
SPKR_TDB03LF-X692N AUD-00002-01-A-R R96
201.5 -512.477 0.45 90.0 TOP PLACED
Rotations have changed on SOME parts?
2010
CON-00349-01-A-R Default R24
210.5 10.273 0.0 180.0 TOP PLACED
2009
CON-00349-01-A-R CON-00349-01-A-R R92
210.5 10.273 0.05 0.0 TOP PLACED
Jeff,
I have had a quick look at your files and the problem appears to be with the IDF generation (emp file), not CircuitWorks.
For instance, the top left component in the 2009 file is R84 (rotated 0) whereas in the 2010 file it is R6 (rotated 180).
Also, as you mentioned, SPKR... is now AUD...
Hope this points you in the right direction.
