When using Convert Entities and Intersection Curve in sketch mode, I am experiencing hangs, lock-ups or crashes. Anyone else? Time for a repair, maybe?
Didn't see anything directly related in the SW KB or in Search.
Click avatar for system specs.
Mine's working fine. I just did both convert entities and intersection curve on same sketch and both worked fine. I can even move the plane up/down and they update as they should. 2010 SP2.1 32-bit.
Maybe a few more specifics on how you were using Intersection Curve or screen shots might help diagnose.
Hi Kelvin
This question has come up before with sw2010. Several commands in sw2010 use the .Net framework. You have mentioned two of them. Some customers have had trouble with not having the proper version installed.
I'll post the information again so that it's easier for others to find.
I've checked with Tech Support and here is what I received:
If the customer is using XP, then use Add/Remove Programs to remove all of the .NET Frameworks in order of highest to lowest (3.5, then 3, then 2). Then, download .NET Framework 3.5 from Microsoft and installhttp://www.microsoft.com/downloads/details.aspx?familyid=AB99342F-5D1A-413D-8319-81DA479AB0D7&displaylang=en
If this is Vista, the .NET Frameworks are already installed and there may be a different issue. We published a solution in the knowledge base: S-044032.
I hope this helps.
Best Regards
Ditmars
Hi Kelvin
I hope this helps.
Best Regards
Ditmars
