I am using routings to auto-route a spline between two fittings. This works well and creates the tube between the fittings well. However as my design changes, the location of these fittings can change. The tubing does not change with the location of the fittings, it remains going to the original location of the fittings. Could someone please help me so that this tubing will change along with my design.
I don't have Routing but I do this a lot with a cross section swept along a path for my ducting.
It may be similar but what I've done is create an assembly level 3D sketch with the route(s), then in each part create a new 3D sketch for the swept profile and just convert the assembly level 3D sketch entities. That way, as the assembly parts change orientations, the assembly 3D sketch updates and the subsequent part 3D sketches update from the dependency.
Again, I'm not familiar with the Routing package but if it works in this "manual" method, it should be repeatable for you thru Routing in a similar fashion.
