I am fairly new to Solid Works and need some help. I am trying to copy the profile of an assembly component to use for a mating component, does that make sense? I want to take the profile on extrusion and create a bracket with the same profile.
What is the easiest way to do this? I tried to import but it tells me it the wrong file type to import.
I think you are looking for convert edges.
If your file type is not one that Solidworks imports it gets expensive quick.
if you can import the geometry start a new sketch where you need the bracket to be and select all the edges you want to use for an extrude then convert entities, if the profiel is good with no gaps and all teh edges convert its just a simple extrude.
If you need to fix the geometry or do any surface work to the model to make it usable it is beyond the scope of a simple reply - but youtube has tons and tons of great videos on getting started with SW
