I am using SolidWorks 2010 and I am trying to add a square butt weld to a a sheet metal assembly. I go to "Insert" --> "Assembly Feature --> "Weld Bead". I selected square butt weld and selected all of the necessary faces and got a couple of different errors. This is the first one that I got:
I changed the mates and size of one of the parts so that there was a .0005 gap between the two components. I tried to create the weld bead again and this is what I got:
I have tried several different things to remedy this problem and keep gettin the same errors. Please Help!
That's what I would do. We often try and model all things including welds when a simple annotation will do.
Steve
I would check with your VAR, they may have a simple and quick explanation as to why the error messages are appearing.
