I am copying surfaces from my "nested part" into my "nest block" in an assembly. When I do this a link or reference is created in my "nest block" under that surface offset. I want to know if I can break this link under my surface offset? I want to be able to move my "nested part" in my assembly without the the surface offset in my "nest block" moving/changing or updating.
Or is there another way I can copy a surface over into my "nest block" so my guy on mastercam can create cutter path for the CNC machine? I also have to fill in holes and modify surfaces on my copied surface.
