I'm working on the can crusher and not so sure about my fixture setting. I have it fixed at the handle and a 100 lb against the slider. Please give me some advise on this setting.
Always same question : what do you expect from this analysis?
If you are looking for disp or stresses when your can is crushed, or before it is starting to buckle, then a static analysis couldbe ok, but you will need to know what is the stiffness of your can (before it buckles).
I don't know, maybe you could fix the 4 holes of your purple part, define a spring between two faces in contact with the can (to take stiffness of your can into account), and apply a force to the handle.??
An other option would be to apply a prescribed displacement to the handle and mesure as a result the reaction force needed to perform this displacement...
This analysis will give results as accurate as your inputs will be.
If you are looking for disp or stresses when your can is crushed, or before it is starting to buckle, then a static analysis could be ok, but you will need to know what is the stiffness of your can (before it buckles).
