Creating Connection Points on Imported Geometry
Discussion created by Guest on Feb 5, 2006
Hi Nathan,
At present minimum bend radius for flexible tubing is rather limited. You can find the min bend radius using standard spline tools. Select the spline, RMB->Minimum bend Radius. This will show the min bend radius value and display where it is - see attached image.
Development Manager - Routed systems.
