I have been having a hard time in copying a file from a template folder and paste it to other location using the Dispatch's copy file command in SolidWorks Enterprise PDM 2010 SP.2.0 !
I keep getting the error message" file could not be found"
Have somebody experienced the same ?
Help !
Cheers,
Bhagavan.
Hi Bhagavan,
Usually this is caused by the fact that you have not provided the full path to the file.
check to see if you need to use %PathToSelectedFile% (is some cases if you would use %DirOfSelectedFile%\%d_filename%)
Joy
